Thread: Comp cams??
Old 10-24-2001, 07:15 AM
ldtopham ldtopham is offline
Cobra Make, Engine: 351c 2v
Default Full spec
Chris,
Your engine is just about what I would like to acheive with my build. I have decided to try and get a Lunati Bracket masterII sent over from the states. The rest of the top end will be springs and caps to suit cam, one peice valves, slight port job, rockers I haven't decided upon yet (roller or stock rockers with needle bearing fulcrum conversion), double true roller cam chain, edlebrook performer manifold (more low down torque than the weixand?), holley carb and electronic ignition.
Your diff ratio isn't far off what I will be using I don't know how the gearbox ratios differ between the top loader (wide or close ratio) and the T5 but the characteristics of the cam you described is just what I req.
Thanks Lee.
