Old 12-01-2008, 11:48 PM
Keithc8 Keithc8 is offline
Default Camshafts and lifters
We do these engines all the time and have a lot of dyno feed back as well as real word use feed back. I can get any camshaft done in a restro-fit for you from Comp Cams for 299.00. We use a steel core on our cams to keep from having any gear wear problems on the camshaft that Comp has had on some of the standard cores, I know because I have replaced them. You can do a retro valley trey and guides and all you have to do is drill two 1/4 holes in the valley using the trey for a guide. You than can use the Ford Racing hydraulic roller lifters for 120.00, the retro kit is 49.00 so you see it gets you out pretty cheap and works just like the factory stuff. I have done a 1000 this way over the years. I can get you the Ford Racing indexable timing set that is a double roller for 69.00 along with pushrods and anything else that you might need. Feel free to call me at 870-246-7460 and we will get you a custom camshaft that will work great for you along with anything else that you need. Thanks, Keith Craft
Keith C
