Old 12-03-2008, 12:31 PM
Jac Mac's Avatar
Jac Mac Jac Mac is offline
Cobra Make, Engine: DIY Coupe, F/T ,MkIV.
IIRC Dean mentioned earlier that there was an issue with the software that was responsible for the 7100 RPM limit.
I do not see why you should be so amazed @ the extra HP, if you visualise the intake valve throat @ 46mm+ dia and then the 42mm chokes in each weber its not hard to 'see' where the restriction is at WOT.
Jac Mac
