Fuel injector installation problem
Has anyone out there had a problem getting fuel injectors into the bosses on Edelbrock FE fuel injection manifold for the FE engine? I've done a lot of injector installations and never had a problem. The fuel rail side fit and installation was easy but no matter what force I use to get bottoms into the manifold, no go. I'm using the mass-flo efi system with the black injectors. Although there is a chamfer on the manifold, it seems like the actual bore where the O'rings go in is very sharp.
