Old 12-04-2008, 06:00 AM
dlampe's Avatar
dlampe dlampe is offline
Yes it was a custom intake. There where no intakes around for an 8.7 deck Yates motor with Weber's. The name of the shop escapes me but it is a 3 piece design. The only modification I needed was a vacuum connection which most people might already have on a normal Weber intake. This system will bolt right to your IDA manifold and you can use your linkage and fuel lines. I already had a return line but I don't know if you need that or not. I switched the fuel pumps and the regulator. Everything else came in the kit from Dynatek. At this point, as bill said, you can't tell the difference. All my wires and lines are hidden under my turkey pan. The only way to know is if you notice the missing axillary venturis.
High Maintenance Racing Team
Run & Gun 2003 - 2013
