  #27 (permalink)
Old 12-05-2008, 05:01 PM
madmaxx madmaxx is offline
I just got back and preliminary results are fantastic, I guess it was making some noise the whole time because not it is perfectly silent but I will go out tomorow morning after it sits all night and that will be the final verdict.
First there is no way to get hurt in lubing the sway bar bushing , nothing is spring loaded etc. The best way I found was to take the 1/2" bolts out of the half circle sway bar bushing support and then loosen the the verticle attachments enough to slide the bushing out. That way you are guaranteed to lube it completely. Make sure you use silicone based lube and not axle grease, Regular dino greases will degrade the rubber over time. You just smear and slide it back in to place and tighten. My were bone dry and no my car has never seen rain it only 6 months old so nothing ever washed away etc.
