  #29 (permalink)
Old 12-06-2008, 07:48 AM
madmaxx madmaxx is offline
Just got back from a drive, full tank of gas 275lb neighbor as a passenger and zero nada noise. passenger side suspension was at 26.5" with neighbor in the car, I hit every bump dip I could find at every speed, turn etc, at 42F and zero noise, the only noise is the trunk support rod. I seriously wonder at this point if I ever did rub the fender, I did see a what i perceived as a rub and wax on the tire but who knows. Lubricating the sway bar bushings is not an option they were obviously making minute noises all the time, although the car is not any more solid than it used to be the perception is that it is since i hear no growls, scraping, squeaking noise when i hit bumps. Stupid little sway bar bushings, who would have guessed.
I used Krytox but it cost $$$$$$$, in other words a tube of grease you usually pay $6.00 for the equivalent amount of Krytox is $400.00 I suggest getting some dielectric tuneup grease for $3.49 at autozone. It is silicone based and the same grease you use on spark plug boots etc. It will work perfect.
