Old 12-08-2008, 05:18 AM
blykins blykins is offline
Default Tremec & Astro A5 Transmission Special
Trying to put out some good deals for the holidays. Unfortunately, Tremec does not allow us to post our actual pricing, just their minimum advertised prices. Email for your price and a shipping quote.
*Tremec World Class T5: Rated for 330lb-ft of torque, 2.95:1 1st gear, .63 OD.
*Tremec TKO 500: Rated for 500lb-ft of torque, 3.27:1 1st gear, .68 OD, 1-1/16x10 or 1-1/8x26 input shaft.
*Tremec TKO 600: Rated for 600lb-ft of torque, 2.87:1 1st gear, .64 OD or .82 OD. 1-1/8x26 input shaft.
*Tremec T-56: Rated for 650lb-ft of torque, 2.97:1 1st gear, .80 5th gear, .62 6th gear. 1-1/8x26 input shaft. Mechanical speedometer.
*Astro A5: Rated for 650hp/550lb-ft, wider, stronger gears than G-Force T5. 2.95:1 1st gear, .62 OD. 1-1/8x26 input shaft. No core required. $2350. 25lbs lighter than TKO 500/600.
Quicktime bellhousings are available for all of these transmissions to mate up to a SBF, BBF, and an FE. Flywheels and clutch discs (stock replacement all the way up to McLeod twin discs) are available as well.
Lykins Motorsports, LLC
www.lykinsmotorsports.com
www.customfordcams.com
brent@lykinsmotorsports.com
