OK, guys - I'm resurrecting an old thread here. I need to buy the fuel pumps now, I'm at that part of the build. The Stewart Warner's are great, but they're unfortunately out of my price range. I have to go with the Facets. Has anyone actually used these? Exactly what is the model number, there are so many different ones. Can any of you guys with a CSX car run out to your car and see if there is a model number on them? I'm going to be running either a 3/8 or 1/2" fuel line, (482" 620 HP stroker FE) and it seems the Facets are all 1/4" fittings. Will a pair of these pumps with only 1/4" fittings restrict the fuel flow into the bigger fuel line? Will I have enough fuel for this engine? Any and all info on the proper way to do this is appreciated. Proper plumbing diagrams (Series or Parallel) for hooking up the pair would be great too. Will I need a pressure regulator for running a pair of these? Thanks.
