Old 10-25-2001, 02:55 PM
BrianPaul BrianPaul is offline
It sounds like it may be a 428 service block. The mirror image 105 on the block denotes a heavy duty block. Check the crankshaft webs for additional ribs. This means that it is in fact a heavyduty block. Approx 20lbs heavier than std. If those are not there then it is probably a 428. Hope this helps.
