Thread: 540 Update
Old 12-16-2008, 01:03 AM
AC-460's Avatar
AC-460 AC-460 is offline
Cobra Make, Engine: BBF 545 Stroker Alloy Heads Roller Cam Aluminium Flywheel Twin plate Clutch TKO600 9inch Independent Rear 335x17 Rear 315x17 Front 1140kg
Looks great warren I can't wait to get my kit its supposed to be ready early march... Do you have mufflers behind the back axle will it be Quiet enough? to pass rego? is the starter fitted from the inside? do you have to leave the carpet loose to access the starter if you need to... you must be getting close to paint!! bet you can't wait
Cheers Mark
