Cobred-
It was mostly small detail stuff for instance- I wanted a 1/2" fuel line from the fuel tank with a return line connection in case I wanted to go with fuel injection in the future. They had already done this for other people. Also, I had them put in stainless steel brake lines.
There are a couple other things that if you don't specify, you might not get what you wanted. There are 2 radiators for the 427 car- one for the expansion tank option and one without. Its the same radiator, the inlet tube is different.
Hey Rick- my car is 2365 with 5 gals of fuel (no seats or carpet in yet). 15" wheels, ERA rear, Pond aluminum FE, QT bellhousing, aluminum flywheel, etc. You can get the weight down there.
