Not bad really. Maybe a touch small on duration - but a good pick if you're gonna keep the freeway cruise speeds under 2800RPM. I normally go bigger - but I do that with everything. If Webers or IR EFI are in your future the mild pick is the better way to go.
The price is pretty much normal - I suspect that any of the regular contributors to the tech on the forum can get you there....with more options.
Survival Motorsports
"I can do that....."
Engine Masters Challenge Entries
91 octane - single 4bbl - mufflers
2008 - 429 cid FE HR - 675HP
2007 - 429 cid FE MR - 659HP
2006 - 434 cid FE MR - 678HP
2005 - 505 cid FE MR - 752HP
