Thread: Cam for 462" FE
Old 12-16-2008, 09:23 PM
Keithc8 Keithc8 is offline
Default Camshafts
This camshaft would work pretty good for you depending on how you want the car to sound and what power you are looking for.
The funny thing about these camshafts is that Comp Cams did not have hydraulic roller camshafts listed till we started ordering them and helped them with what was needed. You have to be careful on what lobe is used because there are some that will float the valves at 5400 rpms because they are to radical for the heavier valves that the FE heads have.
Give me a call and I will be glad to help you get a camshaft and lifter package for 750.00 from Comp Cams. I will have it custom ground for your application and we can recommend the right spring pressures and pushrods for you as well. The hydraulic roller takes a special length pushrod that we have Smith Brothers make for us. Just let us know if we can help.
Thanks, Keith Craft
Keith C
