Thread: Jack-it-up
Old 12-19-2008, 05:09 PM
jmillington's Avatar
jmillington jmillington is offline
Cobra Make, Engine: Unique Motorcars, 331 roller/stroker
I just bought a Torin Aluminum Racing Jack 1.5 Ton from costco.com for 109.99 shipped.
Torin Jack at Costco
Description is:
This low profile aluminum floor jack has a lifting capacity rated at 3,000 lbs. and a saddle height of only 3.35", which allows for storing in small places. This jack has added features that race day units don't have, such as a rubber pad to prevent marring and a saddle that rotates a full 360-degrees.
Four pumps with the exclusive dual cylinder design and you are fully extended with a two-piece handle that has a machined non-slip knurled area for preventing your hands from slipping. Lightweight? How does 26.4 lbs. of easy lifting sound?
Model: T815005L
Low profile aluminum floor jack
Saddle rotates 360-degrees
Rubber pad to prevent marring
Single side grip handle - can be reversed to either side
4 pumps w/exclusive single cylinder design
2-piece handle w/machined non-slip knurled area
Lifting capacity: 3,000 lbs. (rated)
Saddle height: 3.35"
Height (max): 14.76"
Weight: 26.4 lbs.
