Mark
I removed the sensor socket and blanked off the hole. The centre of new hole was about 15mm from the centre of the existing hole towards the centre of the car. If they are moved too far around the length(or lack of) of the sensor cable could be an issue.
If you look at the chassis rail offset you will see the front rails line up with the front suspension mounting points and the rear ones line up with the rear suspension frame mounting points.
Do you know about the mod to the heater hoses under the plenum? This is another job I would do with the motor is out of the car.
Warren
