Yep
Don't get a drive shaft untill the body is mounted. I did and got lucky.
I had the coil overs way up. I didn't know this untill I put the body on (huge gap between the tires and body.) I lowered the coils down to the bottom bracket. Then I had to make some small adjustments to the threaded portion. I think it pulled the drive shaft out or in I can't remember 1/2 to 3/4". I think the shaft was $175 so not alot of money to if you have to do it again. But I would wait.
