I use Vintage Wheels and have never had a problem. I did not use locktite either, after a season or two you will need to replace the pins if removed as they will be beat up upon removal. They do not just come off they require elbow grease and a few skinned knuckles.
35-45 lbs should suffice as they just don't come apart even if loose. Think about it, they need to come loose inside a fitting which in turn is snugged to the unit via the wingnut. Not likely.
