I'll echo a lot of the comments.
The most cost effective budget 390 I would spec for a Cobra would have a freshened up stock bottom end with a set of off the shelf Edelbrocks, an RPM intake with a 750, a Duraspark ignition, and a shelf Comp cam. Cheap to build, would drive just fine in a light car, and would have enough of the external cosmetics of a 427 for shows.
A "funner" version of the 390 would use a 4.250 stroker package, a Comp 282S solid cam and the required hardware, and tuning up the heads a bit. Still reasonable in cost - but more power by a bunch and it'll have that desireable solid lifter sound.
Once you go from a 390 to a 427 of any sort you leave "budget" behind and instead seek value - or glory.......
Survival Motorsports
"I can do that....."
Engine Masters Challenge Entries
91 octane - single 4bbl - mufflers
2008 - 429 cid FE HR - 675HP
2007 - 429 cid FE MR - 659HP
2006 - 434 cid FE MR - 678HP
2005 - 505 cid FE MR - 752HP
