Old 12-27-2008, 11:49 AM
Got the Bug's Avatar
Got the Bug Got the Bug is offline
Question Size of stock oil pressure gauge tube
The compression fitting for my oil gauge started leaking at the block yesterday. The compression fitting on the block side doesn't look familiar to me, as I'm used to seeing a sleeve over the hose with a nut.
I'm running the stock nylon hose that came with the car. Does anyone know if the oil pressure hose and adapter ships stock with the SPF? If so, what is the size of the stock nylon hose?
I plan to upgrade the oil pressure gauge hose to a braided line, but at this point I wanted to get the car back together for a drive.
Doug
