Thread: t5 differences
Old 12-29-2008, 07:25 PM
blykins blykins is offline
I am a G-Force/Astro dealer.
Either one makes a good product, but Astro's gears are a little tougher. Their 3rd gears are wider and this seems to be the weak link in the G-Force boxes.
The Astro A-5 is rated for 650hp/550lb-ft of torque. The gear set is changed to a higher alloy, straighter cut (but not spur gears) gearset. The mainshaft is also upgraded, and a cluster shaft support is added.
Compared to a TKO (I sell those too), the T5 is about 25 lbs lighter, plus you can shift them a little quicker and at a little higher rpm.
Lykins Motorsports, LLC
www.lykinsmotorsports.com
www.customfordcams.com
brent@lykinsmotorsports.com
