  #28 (permalink)
Old 12-29-2008, 10:14 PM
496fe 496fe is offline
Craig (CDNUS) is on the right track. The problem I had was when I didn't have the hex key/socket adapter dead straight in the hole. If you tighten the studs/adapters when the key is cocked even a little you WILL crack them. Either be sure you keep the key wrench perfectly straight when tightening or make an adapter like CDNUS's.
