Old 12-30-2008, 07:30 PM
767Jockey's Avatar
767Jockey 767Jockey is offline
Default Le Mans bowls on a double pumper?
I have a Quick Fuel 950, based on a Holley Double Pumper design. I would like to put Le Mans bowls on it for appearance sake. All Le Mans bowl carbs that I have seen are vacuum secondary carbs, with the accelerator pump on the primary bowl only. Is this the way they all were, or is this just the sampling that I have seen? If so, is it possible to use two primary side Le Mans bowls for the two accelerator pumps? Has anyone done this? Will it work?
