Old 12-31-2008, 07:29 AM
Blittleton's Avatar
Blittleton Blittleton is offline
CC Member / Sponsor
Mikey,
I typically use the plugged hole for the brake booster. I would use it for the pcv if you are going to run it. On the smaller fitting you can run your signal from it. Vacuum gauge? are you going run some type of boost? Why do you need this type of gauge? I don't really like splitting any type of vacuum. Especially the brake booster. This is my .02 worth.
Bill
Squeaky wheel always gets the grease!!
www.gcperf.com
