Old 01-01-2009, 11:50 PM
Gaz64's Avatar
Gaz64 Gaz64 is offline
Rick, just a suggestion as I haven't come across your situation.
Could you sleeve the inner bore with sintered bronze which would act as a bearing as well as the ball bearings.
I'd say the ball bearings must also be worn if the shaft hole through the barrel is worn.
Gary
