  #34 (permalink)
Old 01-02-2009, 08:34 AM
cdnus cdnus is offline
Cobra Make, Engine: 408w 500 h.p. 550 ft.lbs
David,
the nuts we are using are basically a threaded sleeve with a short hex broached in 1 end
which is installed over the original shortened wheel studs.
Yours appear to be for a hub that is threaded, therefore not suitable for a spinner adaptor application. But I'm sure when someone close too you sends you a sample you will come up with a superior solution as you usually do.
Craig
