Old 01-02-2009, 10:23 PM
csx wnab's Avatar
csx wnab csx wnab is offline
Cobra Make, Engine: superformance/427 fe ford
Originally Posted by Badman View Post
Guys,
I've got a five year old 408 with the oil cooler hooked up, Canton seven quart oil pan, Ford FL1-HP filer and have always used Penzoil 20/50, recommended by the engine builder. Good solid engine but the oil presure is only 40 PSI at idle. I'd like to switch to a synthetic oil but have "heard" that switching creates gasket leaks.
Comments anyone???
if you have 40 psi. at idle, you're fine you need only 10 psi. per 1000 rpm. so really, if it drops below 10 at idle i'd worry. now on the other end............you should have at least 70psi. at 7000rpm. this is a theory that smokey yunick proved.
1952 MG TD - 53 HP 1970 SS454 Chevelle - 900hp 2007 spo2669 - 485hp 2001 Spclconst. softtail - 114HP 2006 Roadglide - 88HP
sold Roadglide.....bought 09 XR 1200 - 90 hp stock
i would rather live one day as a lion, than one thousand days as a lamb.
