Hi Pete,
I see you have a ERA 289 car. I believe the external slave kit I make will work in your car. What bellhousing are you using? I have a new bearing retainer and all of the remaining parts needed to install it onto an aftermarket steel bellhousing.
BTW, A Quick Time bellhousing will have the smallest diameter setup that I've been told will fit.
The benifits of an external slave kit is the setup I make has never failed. It doesn't require removal of the transmission to access the hyd t/o bearing and then try to repair it.
http://clubhotrod.com/forums/attachm...1&d=1230323556
The one thing customers have told me over the years is they always seem to fail on a road trip....
Call me with any questions,
Mike Forte
508 875 0016
Forte's Parts Connection
40 Pearl St
Framingham, Ma. 01702
fortesparts.com
508 875 0016
In 1993 Mike made the first conversion of a Ford Tremec to GM 5-speed. It bolts to stock bellhousings w/out an adapter. The FE Tremec, the Mustang adjustable quadrant are originals from Mike.
One of 12 Tremec Elite Distributors worldwide for: T-5, T-56 Magnum & TKO-500 & TKO-600 ,Midshifter, Frt shifter, offset Vette shifter.
Est: 1981 selling performance parts to build your dream car...
