AMAZINGLY SIMPLE HOME REMEDIES
Avoid cutting yourself when slicing vegetables by getting someone else to hold them while you chop.
Avoid arguments with the Mrs. about lifting the toilet seat by using the sink.
For high blood pressure sufferers: simply cut yourself and bleed for a few minutes, thus reducing the pressure in your veins. Remember to use a timer.
A mouse trap, placed on top of your alarm clock, will prevent you from rolling over and going back to sleep after you hit the snooze button.
If you have a bad cough, take a large dose of laxatives; then you'll be afraid to cough.
You only need two tools in life - WD-40 and Duct Tape. If it doesn't move and should, use the WD-40. If it shouldn't move and does, use the duct tape.
Remember: Everyone seems normal until you get to know them.
If you can't fix it with a hammer, you've got an electrical problem.
My wallboard installation rules:
Whatever you screw up, cover with tape and spackle.
Whatever you screw up with tape and spackle, cover with trim.
Whatever you screw up with trim, cover with paint.
Whatever you screw up with paint, put up curtains.
