Old 01-07-2009, 04:50 AM
f16n f16n is offline
Cobra Make, Engine: shell valley,63 427,alum. heads,everything roller
Default cooling question
I have a Shell Valley Cobra with a 427 fe,I have a heating problem at high speed.When I travel on highway for a distance temp. begins to climb 210 or more degrees,When I stop at light temp falls down to 195 or so,changed water pump from eletric to manual,changed thermostats,adjusted timing.Think radiator capacity to small,radiator holds 5 quarts water alone,looking at double pass raditor, Any suggestions please,Thanks Toren
