Old 01-07-2009, 12:31 PM
mr0077 mr0077 is offline
Cobra Make, Engine: ERA 427 SO
Also, a little out there, but check to make sure your lower radiator hose is not collapsing at higher RPM. This could restrict flow at speed, then "un-collapse" at idle or lower RPM for full flow and cooling.
An easy check, warm up the motor, then watch the lower hose while you rev the motor. If it doesn't collapse, that isn't the problem.
Ken
