Old 01-07-2009, 04:55 PM
poboy427 poboy427 is offline
Cobra Make, Engine: SPF #373,Shelby FE Alum Block #077, 488 stroker, Tunnel Port, Dual-TMP DP Holleys
Default Radiator Zinc Anode question
I have a 1/4 inch NPT anode that is about 1.5" long. I am unsure where to install this into the cooling system.
I have a Sleby alum FE and was wondering if I could screw in into the boss where the cooling petcock is on the side of the block. Not sure is it would be abstructive to the coolant flow there or not. Not sure if this site would allow for the anode to screw all the way in or would need to be cut down some. Not sure if this would create a hot spot in this location.
The other idea is to screw it into the radiator itself. I have a Superformance Cobra so I may have to remove the fans,shrould and perhaps the radiator itself to install the anode. I am not sure if the Superformance radiator even has a petcock as I have always removed the lower hose to change fluid.
Anyone have a Superformance radiator/Shelby FE alum block and anode in their system. The anode I have is made by Flex-a-lite.
Open to all feedback.
Thanks Ray
