Old 01-07-2009, 08:28 PM
f16n f16n is offline
Cobra Make, Engine: shell valley,63 427,alum. heads,everything roller
I am running Eldebrock waterpump,used to run CSR electric waterpump but no difference,top hose is stainless pipe with hose couplings,bottom hose is summit racing stainless ribbed hose,running 195 thermostat but tried 160 and 180 high flow but no change,50/50 antifreeze and water mix with royal purple ice,have shrould on electric puller fan,blue thunder intake with all ports cleaned out,eldebrock heads,crankshaft pulley 6.75" dia. waterpump pulley 5.0" dia. with serpitine belt,northern aluminum radiator 18.5" tall by 24" wide with double 1" cores,oil cooler,timing set at 35 degrees total timing,MSD dist. without vacuum advance,MSD 6al control.
