  #21 (permalink)
Old 01-07-2009, 10:39 PM
Barnsnake's Avatar
Barnsnake Barnsnake is offline
Cobra Make, Engine: LoneStar LS427 , 427 Windsor
What voltage are you showing at speed versus idle. Some gauges are highly voltage sensitive and the problem could be the regulator.
I would also verify the accuracy of the sender & gauge.
If that lower radiator hose has a rubber lining, make sure it doesn't have a "flap" obstructing the flow at higher speeds.
Jim
A Gnat! Quick, get a sledgehammer!
