Old 01-07-2009, 11:17 PM
Badger Badger is offline
Cobra Make, Engine: Superformance Brock Coupe
The stock SPF 402 headers were designed to use with AFR 185 heads. If you plan on something larger you'll need to use the 205 AFR heads. The 205s have a slightly raised port so the stock SPF headers mask the top end of the port. Also the primaries are a bit small. Fine for a 402 or smaller but inadequate for something larger. Badger
