  #33 (permalink)
Old 01-08-2009, 02:45 PM
Anthony Anthony is offline
Cobra Make, Engine: CSX4000, 427
I want to buy a new floor jack from Harbor Freight, since that seems like one of a few good choices after reading many past threads. Here's my question. The Kirkham has a round tube frame, but the floor jack has a flat "saddle." Is a flat saddle OK to use to lift a round-tubed car or do they make a floor jack that has a concave-surfaced saddle to fit the round tube frame better? Thank you.
I have one of their jacks. I usually jack the car from the end of the main frame rails, under the cap at the end of the main tube, from either the front or the rear. If I want to put the entire car on jack stands, then I first jack up the rear of the car, and place jack stands at their lowest settings under the frame rails (use the smaller rated jack stands, as they have a shorter minimum height - if you jack the rear too high, then you can't get the jack under the front). I then place the jack under the front, and jack the car to the desired height, and place the jack stands. If needed, I then go back to raise the rear, raising the rear jack stands. Lowering the car I do the opposite.
"After jumping into an early lead, Miles pitted for no reason. He let the entire field go by before re-entering the race. The crowd was jumping up and down as he stunned the Chevrolet drivers by easily passing the entire field to finish second behind MacDonald's other team Cobra. The Corvette people were completely demoralized."
