to answer your question they wired the radio directly to the postive terminal of your battery, your cuttoff switch is after that or they wired the radio to the battery side of your battery cuttoff switch,, very likely. You should easily be able to trace the wire from your radio to the battery and pull the fuse if you do not want the radio.
