I used black and white in my garage but did not like. I have a bus motorhome and its quite heavy, when I would pull into garage and put on brakes it would buckle, also if I wanted to turn a car to put over to one side I had the same problem. Rep sent man out and put screw in a few tiles and helped a lot, but I also did not like fact that when sun hits tile it expands and buckles up. Yes I did leave 1/2" space around edges. Maybe size of garage added to problem and I have 14' tall door opening may add to problems also. I took out and put porcelin tile 12" black and white. Best thing I did, easy to dust off, easy to wash, no movement, looks killer. Now have 2800 sq ft of race deck I don't need, $ 1.00 each to any club member you pick up or pay for shipping. If some member wants real tile I can get for $.97 each. I used 6" rubber base around walls to finish off. Bus motorhome weights 52,000 lbs aprox and is no problem driving on tiles and turning small amount.
