Old 01-09-2009, 12:40 PM
Dangerous Doug's Avatar
Dangerous Doug Dangerous Doug is offline
Cobra Make, Engine: ERA 289 FIA #2108
Bruno's BBQ has good burgers, chicken, fries.
Parking shouldn't be too bad.
What time are you meeting for lunch? I'll try to connect.
I'm putting the Cobra up on jackstands this weekend to give it a once-over prior to taking it down for the CHP inspection. Also, my side pipes are a little crooked, and I realized the engine placement is causing this. I need to reset my engine to level out the side pipes (before I lower it). Also, my e-brake cable popped loose in the tunnel, so I need to fix that before I start tooling around in it. I'll be sans Cobra for the day, but I'll lunch with you and head to Canepa.
Let me know when you're meeting at Bruno's.
DD
Dangerous Doug
"You're kidding, right?"
