eating crow
As far as the 340 my brother said the cam was a mild cam, lift was about 478, set of headers and a 650 DP holley. Compression check on my FE came up with the high cylinders having 140PSI and the low at 125PSI, throttle was at WOT, all spark plugs removed and a 15 amp battery charger running and engine at operating temp160 - 170 degrees. Thats why we are going to check out some other stuff hopefully this weekend.
