Slave cylinder travel distance
Bill, the new bracket looks great. I assume this setup requires the use of the longer clutch arm that pivots on the passanger side (inside the bellhousing) becuase the pusher slave is pushing toward the front of the car to disengage the clutch, right? I believe this set up requires more clutch arm throw. I have about 7/8" at the arm tip and I need a little more.
Secondly, I am looking for more slave cylinder travel. What is the throw in the ford pickup truck slave cylinder? What diameter clutch master cylinder are you using?
