Cobra29,
This clutch slave cylinder will throw at least 1 inch. But I will have to confirm this on Monday. I'm the only one at the shop this morning. In the backdraft's slave cylinders, we use .750 dia. bore. the slave cylinder is also a .750 bore.
One thing to make sure that your pivot pin is adjusted more toward the clutch plate. If you have too much gap there, it will be very difficult to get proper throw on your slave cylinder.
Bill
Squeaky wheel always gets the grease!!
www.gcperf.com
