Originally Posted by Paul F
But...but we haven't finished this one. David suggest we make the tapers match and make them out of good material.
David, you made a bunch of pins. Can we use them?
Hard to answer. Depends on your adapter.
Our pins are 90 degrees so they will fit a 90 degree taper. The Vintage hub adapters are a 60 degree adapter. We can make those too, without much grief.
The only adapter I have measured is a Trigo. It is 90 degrees. I assume the Vintage hub adapter is 60 degrees, but I don't know. I'd need one to measure.
Also, I don't know about the Compomotive; I'd need to measure one.
David
