  #183 (permalink)
Old 01-10-2009, 07:01 PM
Paul F Paul F is offline
Senior ClubCobra Member
David,
I backlit it as you suggested and saw no light on the unused holes (there is two sets of 5 holes). On the holes I have used, with it backlit, I can see the distortion at the bottom of the taper where the pin made contact. The taper has been pushed down and is no longer 90 degrees at the contact area. But that's ok. I have the other set of good holes. I'm now wondering if the baseplate of the hub is no longer flat. I'll check that later.
