|    Not Ranked
 Madmaxx, You have to see what is "closing/connecting" the trigger circuit.
 I suspect the two wires leads that go to the temp-sender as screwed in the block will turn on the fans if connected together. my guess is that there is a problem here.
 IE: if they connect to or touch eachother, or if one if them touches a "Ground" (engine block, bare metal ) this will make the fans turn on.
 your sensor/temp switch could be malfunctioning, or the wiring could be pinched.
 Let us know what you find/need help with further.
 Blas and I are both bigtime E' geeks.
 --Steve
				__________________Steve SPF 2734 MK3 / Brock Coupe #54- panavia.com
