Originally Posted by Gaz64
Lads, overlap has nothing to do with compression pressure while cranking.
The valve event that influences cranking pressure is inlet valve closing point.
Yep, "overlap" gives you that pleasant "rumpety, rump" sound, but cranking compression really gets going when the intake valve is closed. Here's a graph of my cam. You can see on the compression stroke that my intake valve is still hanging open (the blue line) a good half way down on the the piston's travel. If my IV closed sooner, my cranking compression (and dynamic compression ratio) would be greater.
