  #47 (permalink)
Old 01-12-2009, 02:23 PM
Rottie Rottie is offline
Cobra Make, Engine: Kirkham, 482 Shelby / TKO 600
David,
Can you supply the modified QT Bellhousing for the clutch set up? I assume all of the bolts from the bellhousing to block are still used? I saw another set up and the slave mounting bracket did not allow access to one of the bellhousing bolts. Sorry for all the questions, I just want to make sure that I know what I am buying. I search for a picture but could not find one, do you know where I can see the set up?
Do you recommend the QT bellhousing or a different one?
Thanks,
Peter
