Originally Posted by Rottie
David,
Can you supply the modified QT Bellhousing for the clutch set up? I assume all of the bolts from the bellhousing to block are still used? I saw another set up and the slave mounting bracket did not allow access to one of the bellhousing bolts. Sorry for all the questions, I just want to make sure that I know what I am buying. I search for a picture but could not find one, do you know where I can see the set up?
Do you recommend the QT bellhousing or a different one?
Thanks,
Peter
Peter,
What motor? FE or Small block? I'll post pics.
We like the Quick Time bell housing. They are much lighter than the Lakewood.
Yes, we can supply the bell housing. We charge $100 to modify it. The clutch fork opening has to be slightly enlarged. Then, we cut the bottom flange off so it won't catch on road kill.
David
