You can fill the clutch master cylinder from a small bottle of fluid. Put the bottle next to the cyl. before taking the cap off, then pour into the cyl. I replaced and bled my slave cyl. by myself by alternately pumping the pedal and filling the master. After cracking the bleeder open to let the air out a few times, I was able to get all the air out of the system. I see by the build # that your BDR is one of the earlier models, have rerouted the hyd. line and installed a heat shield? Search earlier threads for details.
Good luck!
