Old 01-13-2009, 10:45 AM
jmacanderson jmacanderson is offline
Cobra Make, Engine: West Coast
Default West coast for sale?
I know this isn't really the right forum to sell a cobra, but due to a lack of work in the construction industry, I may be selling my West Coast Cobra. I am just putting some feelers out to see if there is anyone semi-local that may be interested. I live in St George Utah. (1 1/2 hour north of Vegas)
It was built by G-Tech Engineering in 2005. He still has some pictures of the build on his website www.gtechcars.com under featured cars. (do not pay attention to his home page that says sold, that is from when I purchased. it is still for sale.) I have literally hundreds of pictures of the build. I tried uploading some of them but they exceed the limits.
Below is the description of the vehicle from when I bought it. If anyone knows someone that may be interested let me know. Thanks
Vehicle Description: 427 Custom Cobra Recreation
Engine and transmission: 460 Ford Big Block crate engine, 550hp, Super Cobra Jet aluminum heads, painted block (red), Street Demon 850 Carb, special made Cobra 460 valve covers, Cobra air cleaner, Taylor wires, MSD 6 AL Box, Electronic Distributor, Pro Torque Starter, polished stainless headers, Fuel pressure regulator & gauge, chrome coolant expansion tank, Earls stainless lines, special Show Chrome around engine compartment, fully detailed engine.
Transmission: Richmond 5 speed, Long shifter, Lakewood bell housing, Center force Dual Friction Clutch, special design external hydraulic clutch system.
Body: Stallion style, 6" Longer 4" wider than original, PPG basecoat, clear coat, unique awesome 5 step paint, base is Intense Blue, Silver stripes, base clear with prismatique (glitter), pearl cover, high build clear coat 3 coats, Blue is much darker than picture shows. Must see this sparkling paint job. Picture does not do this paint job justice. Finished underside of hood with stripes as well.
Frame: Tubular space frame designed with safety in mind, painted yellow steel brake & fuel lines, electric fuel pump, Fram pre filter, 20 gallon aluminum fuel tank, 7 core radiator.
Suspension: Rear: Ford 9" Posi unit 2-73 gear triangular 4 bar coil spring, disc brakes, emergency brake and sway bar. Front: Tubular upper & lower control arms HD brake caliper, 11" rotors, power assist rack & pinion steering, power 4 wheel disc brakes.
Wheels: American Racing Torq Thrust II 15x7 Front 15x8 Rear, BF Goodrich Radial TA Tires, 225/60R-15 Front 295/50R-15 Rear
Interior: Black leather like luxurious sport style interior, tilt steering, Grant steering wheel, wrapped dash & console, fully carpeted gauge panel with 10 VDO gauges, fuel shut off, battery disconnect, Blue RCI Cam lock racing seat belts, large capacity trunk fully carpeted with trunk light, Optima 800 amp battery mounted in trunk.
